remap tommorrow
zippyy
87
Macclesfield
I am getting my Leon TDI FR remapped tommorrow by Simon Coe. What is the highest torque I can go for without frying my clutch?
Fastbaz
Fastbaz
Nov 26, 2006
91
west midlands
i believe it is 300 lb/ft max but better to get it around 280 ish gives you a little safety margin and from some of the comments from others who have been down this route you will need to change your driving style a little, change down a gear rather than just floor at real low revs it as i think this is what screws the clutch. what brake horse power due you reackon you will be getting 190 ish or more? let us know as i a thinking of getting mine done soon....
lard44
Watching C beams...
Apr 30, 2007
474
Braintree, Essex
Yup 300 is the OEM limit, although mine was slipping a little at 285-90. Just change up later or change down if you want to boot it.
Let us know what the results are...bet you won't regret it tho!
zippyy
87
Macclesfield
Had it done, but its a bit wet for a good test run. The clutch seemed fine on the little run I did do though. So fingers crossed.
I will let you know how it goes if it ever stops raining.
Got it done through www.ccctech.co.uk and uses Upsolute files. Cost was £275.
muddyboots
Still hanging around
Oct 16, 2002
5,739
It's not a custom map as such, but you can request changes to the stock map - for example you can have a stronger top end, or reduce torque between certain revs. Simon doesn't alter the maps himself, he sends the requests to Upsolute and they send him back the revised map.
I had my Passat done by Simon, and I wanted to be absolutely sure my clutch wouldn't slip (didn't want to fork out for a new one, and existing one is quite old) so had the torque pegged back between 2000-3000rpm.
Peak power at the upper end of the rev range remained unchanged, and I achieved 175bhp at the Awesome RR day, not bad considering the engine is on ~130k miles.
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Unfortunately with time the clutch will wear away and you will get clutch slip. The clutch on the TDI 150 are a weak point.
