Good luck! Is the seal cord just the foam seal that goes around the panel behind the door card?
According to earlier in the thread its some sort of sticky rubber seal but i'll post up details when I get it
look's like they have finally recognised the fault - no chance of a recall for this though so warranty only or pay up or DIY
Does anyone know what part number this is?
If not a mate and I are going to have a go at the remaining 3 doors and look at the other one I attempted. Going to be removing the old foam seal from around the door panel and using some seal/mastic on a role. Its like a role of selotape sealant stuff, should be much neater and cleaner to use. After the panel has been fixed on I will be running a bead of clear silicon around the door panel before refitting the interior panel.
What clips are those matey?
Yes. Follow the advice on the first page, very useful. It took 20mins per door once i'd finished the first one. Good tip is don't unscrew the door card completely, only need to untighten it enough to remove the dodgy seal and replace it with the new one.
