Horrendous Steaming!
danmay
Fast cars, shooting stars
Mar 25, 2007
1,389
Stafford
www.myspace.com
with all the toss weather we've been having recently i've encountered a wierd problem with my car steaming up horrendously1 the only way i can clear it is by flicking the air con on the windscreen for 5 mins, but the problem is that i'm bloody freezing my nuts off!
This hasn't happened before, but it's really annoying, have cleaned all my windows and drove with the window down, but the entire car really badly steams (which looks really dodgy when the gf is in the car lol)
anyone else found this?
at least my headlights don't steam up yet ;)
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
first thing is to check that you don't have the recirc button on all the time on the climate
second thing is to check for wet carpet in the rear
I do hope it's the first one :(
danmay
Mar 25, 2007
1,389
Stafford
www.myspace.com
i've checked and i can't see anything wrong at all, the entire car is bone dry and the windows are all properly sealed, i attacked it with a hosepipe last night and nothing leaked so i'm confoosed!
i had the recirc button on for a bit and turned it off, that lead to more problems lol, it's been mashing it down on my drive to work this morning and had no problems...wierd!
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
mines weird it clears fully but leave 2 little steemed bits on the bottom of the windscreen (where the fans are) thinks its normal though lol
Ant FR
2,861
Kent
probably a leak somewhere.
One thing to do is try and dry the car out. You could leave it running for say 30 minutes on the drive with the aircon set to hot and recirc. This effectively takes all the moisture out of the car and you should see a nice puddle of water under the car where the moisture comes out. Acts as a big dehumidifier. But when back in the car ensure its back on external air supply.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
if its really bad and dripping then i'd suggest it has a leak or damp getting in somewhere usually the pollen filter loose is favourite
if it's not that bad try cleaning all your windows and then seeing how you go
after about a month of wet/dry etc you'd be surprised the difference it makes cleaning em up
topleya
MK5 Ibiza FR Black 1.2TSI
Nov 23, 2007
78
i have the same bloody thing, really annoying. get in car and windows are clear, start engine and withing seconds i cannot see a thing. really annoying.
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
I have had the same problem but only when it was frosty/freezing out side. I'm sure its just the pollen filter as johnbev said so I'll be changing mine next month.
air121005
1,609
Worcestershire
this exactly whats happening to mine! :(
i'll check the pollen filter, TBH would never of thought of looking at it! :rolleyes:
thanks for the tip :D
