Quickshift
Ok guys I realy need your help on this one. I have just finished building a mk3 Golf which I fitted with a 03 Ibiza PD130 engine and 6 speed box.I used the full Seat loom,ecu,clocks etc.
The car starts and drives fine until between 60 & 70mph it goes into
limp mode.If I turn off the key and restart the car it is fine until I reach
60ish again.
There is also loads of black smoke(I mean loads) out the back when I
drive it on,it is even very smokey at 60mph in 6th gear.
I had it plugged into vag-com and there was no faults,we even drove
it plugged in and nothing came up when it went into limp mode.
I took off the turbo,stripped and cleaned it,cleaned the erg and intake
manifold but its still the same.
The engine(ASZ) has only 1735 miles on it,I fittedd a front mount intercooler,
K&N cone filter and took off the cat.
Please help.
60ish again.
Please help.
