I have a couple of pics of mine.. You can see in this pic how the whole system sits in place, and the 80mm cold air feed that does make it past the battery tray to the front scoop.
Modified bracet number one, this is the orriginal bracet that came with it, that i cut and modified to fit.
This is my replacement battery tray bracket that i made from mild steel, cut, heated and bended into shape. It has a rubber damping washer underneath it to cushon the shock to the MAF. I also had to make the collar up that goes around the MAF housing, to drill the bracket too, this is also lined with rubber strip. You can see the plastic where it has snapped off from the original bracket.
Just another pic so you can see the brackets.
I know DJP has slightly different views as to the set up of this, but i have had mine on for well over a year now, and i have had no trouble at all. And logged 198Gps, before i fitted my new cold air feed and scoop.
Hope this helps mate
