RAF A8510437
Ive got a 2003 tdi (130) ibiza and iv just lost climate control. I have no idea why :confused: . The indication pannel is still showing readings but i have no cool air entering the cabin. Iv checked to see if their is any gas and their is so if any one can shed any light on this plz then that would be great cheers
Right on bud ill have a crack at that when i get a chance cheers
Are the fans kicking in when the engines idles? (to keep the temp down)
I'm not sure if it's the same in the Mk4's but with the Mk3's - one fuse controls all the fans, if this goes - the air con goes, the cooling fans go etc etc...
I found this out in the Q at Trax, where 2 weeks before I thought "oh, my air con's gone"... then it got uber hot in the Q.
It's worth reseating them all just incase, as I didn't need to replace mine (although I did do) to make it work again.
Sorry if I'm wrong, but might be easier if you can't get to vag-com easily.
The fans does not appear to kicking in so ill have a look at that and im going to be heading back home next weekend so will get them to vag-com. right on
Cool - sounds like it'll just be the fuse mate (it's a 30A if you get chance to pick one up before you check - just incase you need another one)
Mate cant find any 30a fuses in the fuse box to the right of the dashboard. dont know if maybe their is another fuse box that i havnt found? and the fuses in that fuse box are all ok :confused:
Off topic, do you reckon its wise to use your service number as your login?? Just a thought. ;)
Good choice of motor by the way, whats it like being a stranger at the filling stations??
I can only go from my experience from my Mk3, but there's another smaller box on or near the battery, there are another 3 fuses on there. From your symptoms, I'd say it's gotta be the fuse, but where that fuse is on the Mk4 I can't say for sure... i'd check near the battery though.
Sorry I can't be more help.
Was just thinking the same, dude, loads of interested people on here that your in the services, If you know what we mean :doh:
By the way, my air con did the same, leak from a union on the bulk head, sorted the problem and had a re-gas, works fine now, all under the warenty.
______________________________
2005 FR+ in Black Magic Fabia Rear Wiper, Connects2 Mp3 Connection, more to come
