Have you ever claimed on it? My worry with aftermarket warranty is that its like insurance - they'll do anything to get out of paying.
If I extend it, it'll be through SEAT.
I have a clunking noise on my 130 sport 02. It comes from the passenger side front wheel when you pull off and go over bumps...any ideas?
Has anyone had any problems with rear wishbone bushes wearing badly? what price am i looking at?
I have the same clunking noise, but i never know when it gonna happen so i dont know where its coming from!! sound like passenger side!! chris..
I used to have the noise, until I replaced the bushes and the track rod ends... so far it's been as quiet as a mouse![]()
were the track rod ends worn then player? i can understand about the bushes... chris..
Turbo manifold bolts on 20vt
these can work lose on mapped or standard car, starts with a loud whistle like kettle when on boost then gets more like blowing exhaust. fixed undr warrenty needed new gaskets and bolts happened over easter bank holiday so was with out car for over a week should be done in 2 days.
I have a grunting sound when i accelerated, sort of sounds like a blown exhaust, worse when engine put under pressure> i have on 03 tdi sport 130 diesel, do you think that could be the bolts?
![Furious [:@] [:@]](/forums/styles/seatcupra/oldforumsmileys/furious.gif)
my wife owns a little 1.2 ibiza chill in yellow on a 56 plate.
picked it up in april with 46 miles on it.
it has now got just over 1000 miles on it and the power steering packed up today.
called seat assistance they couldn't work out what was wrong so told my wife to drive to local dealer.
they have now got the car but not sure how long they will have it for.
but got courtesy car for the duration.
anyone else out there had a similar prob on such a new car.![]()
brought my 2002 1.2s in July 2005.
1. Drive it off the forecourt and 1 mile down the road the temp gauge goes right up and then engine cuts out. It had an oil leak aparantly which dripped onto a belt and made it slip and then it shredded! - fixed under warranty
2. Grinding/rubbing noise coming from front when going over bumps - had roll bar bushes replaced under warranty - problem is still there
3. Drivers window regualtor goes while on the M6 - problem fixed under warranty
4. Remote central locking stopped working - key replaced under warranty
5. leak coming from somewhere - drivers and behind drivers footwells are soaking wet, have to wet and dry vac it every time it rains - had door seal replaced, window seals checked - still not fixed
6. Cigarette lighter only works when it wants to - and even then doesnt get very hot - socket isnt even producing enough power to charge my phone - not fixed, not in the mood to spend money on the shed!
7. Passenger door refusing to open - wont respond to the remote key and wont let me pull the pin up from inside either. Cant put the key in the door cause the passenger side doesnt have a key hole! - still not fixed (hoping to vag com it at coombe abbey meet)
7. Timimg chain slipped, tensioner snapped = £350 bill. - fixed reluctantly
and the latest...
8. Rear washer jet not working - am guessing the pipe has come off - not fixed.
I really do love my car
and the latest...
1.4 Sport 05 Reg
Speed sensor failure at 7777 miles. Car started to lose power and put it back on again whenever it wanted to.
Fixed under warranty
Fuel gauge started giving erratic readings.
Since the car was two and a half years old I have had problems with the aircon. It can do cold - "lo" and it can do "hot" - so anything from 18C-24C comes out as 28C! The fan is also very confused, it blasts out air then cuts out, then blasts it and cuts out again. At the 3 year service they replaced a part , said it was one of the fans not working (they took the dash off), but it's no different now. I could not afford to go back there as the dealer is not nearby so I left it. I'm due a 4 year service in July but it's now out of warranty and going to be expensive to fiddle with the air con.
Oh that reminded me, had the air con unit replaced.. twice!![]()
Could just be the IC pipe vibrating, does it do it on tick over ?
