Send a PM=Private Email (click on my name by this post) for pictures not words
Yes you can see it enabled by the ECU code change.. it is G at the end on top right of screen... if you enable it;
"Then the engine ECU needs to be programmed for cruise. The engine ECU (01) needs to activated, this is done by entering the login (11) code -11463. I used my Vag-com, however on later cars (late 2004/2005) cars this can only be done by a dealer using their VAS computer." .. said someone someplace somewhere (sorry someperson ...lost the reference).. then you find it throws a fault code if you have not wired up the cruise. I also had to come back out of Vag-com after activation and then go back in to check for fault codes or it threw a code when activate then check for fault codes
To disable cruise control enter 16167 instead
.. all careful/techie DIY'able with some searching and Vag-com.
