k04 ibiza
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
it may just be that mine made more noise n drives alot different to yours! mines abit more raw (no sound deadening etc)
i had a huge green open filter (see pics afew pages back)
Feb 25, 2007
657
stroud
the car has allready been mapped why would it need it again the cars are the same nick has all your bits you swapped over might be the blow on the exhaust loosing power nick just cant wait to get the car back
i cant wait either to see the conversion
h17och
Sep 1, 2005
3,504
Dunstabubble
yea its got 4bar on
didnt put oil filter on as the old oil was really clean and the oil filter looks pretty clean too so i guess it been done not long ago!
sorted exhaust, had to take abit of time off of work but i took it to the place and they sorted it!
the exhaust has got a little knock on start up but i will look at that
i forgot to mention about a oil ctach tank but i found away around by using the ibiza breather method with the 225 tip!
you need a different DV tho as the one on there (diaphram) just chatters its tittys off! so i put my 007p on and its much better!
sortd other abs ring
just needs stereo now!
h17och
Sep 1, 2005
3,504
Dunstabubble
also power is better now! lost the flat spot!
its a much smoother drive than my car, i like it! mines like a noisy tractor compared
Feb 1, 2007
1,293
gloucester
i will go and grab a 007 from forge tommorow , i did notice that it chatters it tits of , whys that , i got 0.4 bar more when i chucked it on the leon , it peaked at 1.5 bar hen went down to a bar what it usualy goes down to
h17och
Sep 1, 2005
3,504
Dunstabubble
im not sure why its chattering wiv that DV but i know its not good!?
let me know how much forge will charge you as i can get them pretty cheap!
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
stevegti6...the reason i said about having the map tweaked was because once you have the AFR guage and wideband on you can get the mixture more presise (spelling) on the map...which means more power!
iirc MRC said its a tiny bit rich at mo but they will fine tune once AFR guage is on
HoocH
