as above, my brothers 60k miles 2002 130 tdi sport was misbehaving last week and he asked me to look at it for him ( he ain't got a clue what end of a screwdriver goes in the screw )
anyway the fuel and volt gauge's were intermittent, if they were off and you gave the dash a thump or just put ignition off/on a few times they would work again for a bit
so the plan was to disconnect battery, remove airbag, steering wheel and dash binnacle and have a look
no chance of removing airbag as one of the clips was broken and only one side would pop out making it a case of rip it off and brake it or have another idea
managed to remove all the clock binnacle and steering column trim
then found that the steering wheel not only tilts up/down but comes out/in too
so checked my FR and that was the same
never knew that
this made moor room to remove the dash binnacle and it came out well easy, looked at it and found dirty/tarnished/corroded pins in the multi plug behind the speedo, cleaned them up with a small retractable fiberglass pencil type brush and put it all back together
so far so good and I also removed the trumpet thing inside his air box and advised him to get a pd160 intake and green filter ( there is now way he will but you never know )
anyway my question is, has anyone else had this problem ?, did a search and found nothing
never knew thatthis made moor room to remove the dash binnacle and it came out well easy, looked at it and found dirty/tarnished/corroded pins in the multi plug behind the speedo, cleaned them up with a small retractable fiberglass pencil type brush and put it all back together
thats one of the features in the
) i might give it a try!
