Anyone experienced this??
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Just recently I've noticed that there is a fan coming on quite soon after I start my car. This seems to draw quite a bit of power from the engine as the car revs slightly higher to accomodate this. This is not the AC one and have had the car since new (2003) and has never done this before. It should not be an engine cooling fan as when it comes on the car is not up to temp yet.
I do have a dodgey coolant level sensor, could this have something to do with it??
I've had this dodgey sensor for a while (3 months) and the fan has just started doing this
Any help would be appreciated
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
You sure your air con is not left on? as they switch it on automaticaly to prevent overheating
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
The only fans that I can think of that would kick in and cause a noticable power drain, are the two fans at the front of the engine bay. If they are coming on it's either due to a fault with them, or a fault with your temp sensor that makes them think they have work to do.
The first thing to do is change the sensor. They can get progressively worse as time goes on, so the fact this is a new problem (fans I mean) isn't entirely surprising.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Sounds like a problem for vag.com?
RobM
Sep 27, 2006
4,982
Southampton
Could be? Might just flag up a faulty temp sensor though, which you already seem to know about?
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Aye you could be right. Untill I change this it might be a waste of time. Looks like I'll need to change this before i proceed, cheers for your help.
I'll double check tht the AC is not on too and monitor which fan is coming on
RobM
Sep 27, 2006
4,982
Southampton
That definitely sounds wrong. I'd be sure it's the temp sensor tricking the fans into thinking they have work to do to cool the engine down.
RobM
Sep 27, 2006
4,982
Southampton
That's also fairly normal, they don't stay on constantly. They turn on, give a good blast and then settle down. You can hear them doing it if you get caught in traffic on a hot day.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Aye thats fair enough, will get this sensor changed though. do you know if its a self fix or a garage job?
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
i would say your fans are fubared as i have had my temp sensore changed and mine still do this and my temp gauge also goes over 90 every 10-15 mins of driving or sat in traffic i then have to turn the air con on to get those big fans to kick in to cool it down. Sometimes the fans dont kick in at all and i think this is *** the small fan is buggered so the big fans kick in more often. I dont know how much it costs but have heard its expensive
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Can you give me any info on changing this sensor?
Any help would be appreciated[B)]
del 77
mine was doing the exact same thing, coolant warning light was also coming on and beeping when i started it up each morn. (coolant level was fine) I recently had water pump and cam belt changed and both have stopped happening since it was done.
