I'm from Holland, and here we have many 18-20VT's on LPI
Vialle LPi:
100% engine capacities the Vialle LPi autogassysteem are unique, because it works on the basis of liquid fuel injection. Autogas comes in in liquid form and under very high pressure in the gastank of the car.
Most of the systems the liquid gas is evaporated, before it is injected in the engine. At Vialle LPi this does not happen. Thanks to a pump, which has been placed in the gastank, the gas is injected in liquid form in the engine. This has a cooling functioning on the engine, as result of which the engine is charged less heavily. Still it is more important that with this system the engine performance and strength of the car remain preserved entirely. Space-saving tank solution much-heard complaint concerning driving on autogas is the large cylindrical tank which confiscates a large part of trunk space. Modern tank solutions are however placed on the spot of the sparewheel or under the car. Because of this the luggage space is not charged or hardly. ring tank on the spot of the sparewheel the ring tank becomes at present most applied and gives a beautiful result. In many cases the floor of the luggage space something is raised to be able place an as big as possible tank.
Gross and net tank reserve autogastank are in several half-measures deliverable. In most of the cases by type of car as contents optimum as possible are chosen, varies of 47 litres ring tank up to 100 litres cylinder tank. This is gross the contents of the tank. If the temperature increases in the tank, autogas outfit. To give the space to the gas to expand & to shrink without the risk of the securityproblems, is only possible to fill a gastank to 80% of maximum . At the Vialle LPi system a pump has been placed inject the fuel liquid. This goes for a small part at the cost of the contents of the tank, which can become as a result between the 70-80% full.
Drive with Vialle LPi
Drive with gasFX works exactly the same such as drive on petrol or diesel. After starting the car, you drive some time even ordinary on petrol. After a couple hundred meters the car switches over automatically on gas. Here you notice nothing . On the display of the autogassysteem, which has been assembled on your dashboard, however after the start you see a candle blinking. If this stops blinking you're driving on autogas
a little bit babbelfish and a little bit myself, i hope you understand it
