yeh ive corrected that now thanks. yeh i think ill stick with it as it is and just get the spacers. Ive got a few other bits going on soon so ill put the pics up so u can av a proper look
you u av a luk @ nt usin txt spk
there is definatly a diffrence! areyou 100% certain they are adjusted the same have you looked under the back of the car at the bottom of the struts to see?? are both the springs sitting in the correct locations actually that is a good idea, im taking it back to where it was fitted tomorrow so ill c wot they say about that. Hav u done that on yours?
Theres no point in taking the piece of my case
Are there platforms that the rear springs sit on? If so, whip them out!
I found my KW v1s wouldn't go low enough on the back, so took the platform out and it went to the perfect height.
The springs may be a bit loose while the cars in the air but when its on the ground, they won't move anywhere!
