Inlet sorted thanks to Forge!
Basically straight out of the Turbo, under the linkage (no 90 degree kinks) into the LCR/S3 TIP, up to the MAF (but a bit further forward than normal because it's moved 140mm towards the wing. 90 degree silicon bend into the air filter which will sit pretty much where the battery is.
Some work still to be done to connect turbo outlet to pipework, as the forge pipe we have is ace, but we need to make it longer! so that's WIP - it's that or the intercooler pipe doesn't sit where it once did
Injectors are at the PO awaiting some VAT & Import duty to be paid... but it's getting there (not bad given the total lack of time I've had recently)
