anyway Cupra Ross just want to say at the end of the day " I love U " and no hard feelings
Of course mate. Nothing wrong with a bit of vigorous discourse. BTW, nice motor!
Nope, still the same even when mapped I know i owned a fairly well tuned R up until a few months ago.
5500 rpm is still the sweet spot, after that is just a waste of rpm.
And you can tune the 2.0L too, so im not sure where that point came and went too.
In my own experience the 20VT revs fine up to the red line, looking at the engine specs between mk1 and mk2 they actually seem very similar
Leon Cupra R
225.1 PS (222.0 bhp) (165.5 kW) @5900 rpm (198lb/ft at peak power)
280.0 Nm (207 lbft) (28.6 kgm) @2200 rpm
Leon Cupra
240.3 PS (237.0 bhp) (176.7 kW) @5700 rpm (218lb/ft at peak power)
300.0 Nm (221 lbft) (30.6 kgm) @2200 rpm
(seats own website says 5100rpm and 206lb/ft, bit of a mistake there)
both cars produce peak torque at the same revs and peak power at near enough the same revs, on top of that they both look to have a similar spread of torque from low revs up to peak power
its difficult to see how you could accuse one engine of being breathless and not like being revved and the other engine to be the opposite when they both seem to have been set up in much the same way
Don't remember accusing either engine of being breathless, put words in your own mouth, not mine.
I witnessed a new Cupra put out 266bhp standard last week, similarly one also developed similar figures at another independant RR the week earlier.
I would love to know whether these quoted figures are actually at the wheels figures (unlikely IMO). What are the actual at the wheels figures, as thats the only BHP reading worth comparing.
It will also make a differnece knowing if the RR was calibrated, against what, when and by whom. Otherwise these figures are no more than just fishermans tales.
Dont get me wrong, I am hoping these are acurate and that the FR TDI is similarly understated as thats what I will be driving when it arrives.
In line with your statement, the manufacturers figures are just as much pie in the sky. Do you know how they tested the engines, was it in the car or on a bench dyno?
The car run last week at Awesome produced 247 atw 266.9 clutch
No doubt there will be doubters, we come to expect it.
I ran my Leon R on many rolling roads, and rarely got such good 'repeatability' as it did on Awesome's RR.
But always remember Dyno Lottery, search an ye shall find.
That's my point exactly, Awesome gave a reading of 266.9 at the clutch, thats just a guess as they can only guess as to what the loss is between clutch and wheels where the readings are usually taken. How did they work it out? by adding a % or just plucking a figure out of the air as every single car will be different (not every single make but every single car)
Now the 247 wheel reading is one every can use and compare more acurately against. Even allowing for slight differences in RR's, the wheel figure should be relatively close.
Bloody good ATW figure 247, I would be happy with that as standard (over 7bhp higher than manufacturers Flywheel? reading)
Personally i think its laughable a FWD car can lose the same power as some small cars have in total, simply through their transmission alone.
Thanks for your comments. Unfortunately, I have already discarded the BMW 130. I am a big fan of ICE, and the local dealer informed me that if I install even the smallest non-original piece of equipment, I would void my warranty.
I think i would get a second opinion on that from other BM dealers, some dealers don't have a clue what they are talking about and will feed you full of **** to make more money out of you. I think they'd be hard pushed to stop you claiming on a warranty for a break down due to a stereo and speakers if correctly and proffesionally installed.
