Is my abs ok?
Poverty
When my abs kicks in, the brake pedal kicks backwards, and it makes a disgusting crunching sort of noise, is this normal for the ibiza or should I be having a word with my dealer. The old mans volvo sure doesnt do this.
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
yup, normal
its the sound and feel of the brakes juddering so as to stop you skidding
all cars with abs do this
heavy cars can take a lot more stick on the brake pedal before the abs kicks in cos the weight means more grip
try the ovlov on some loose gravel
gazjones
yep feels really weird and sounds horrid and feels like your not stopping at all!!!
Poverty
I see, when I had to stop quickly today my ABS kicked in and my GF was like WTF have you broken your car already :blink:
Are all cars ABS systems really like that, as my gf's dads merc doent make that noise, or my dads volvo!
Nath.
Jan 1, 2006
8,620
16
yup, normal
Poverty
yup, normal
Thanks for the info. ;)
depresion
484
Yes it's normal the ABS is pulsing the break fluid pressure rapidly, (the noise is a combination of the pump, the pads on the discs and the pedal juddering) the pedal feel is the change in pressure.
It's feasible that the Merc isolates the pulses from the pedal using some high tech electronic jiggery pokery as they also have EBA that will apply more force to the disks based not only on how hard you press the pedal but how quick you press it as well. (Most people don't use more than 75-80% of there breaks even doing an emergency stop so if it thinks that's what you are trying to do it uses full pressure)
