B&M Short Shifter Fitted (Ebay Copy)
bigjode
504
Just a quick one, was yours listed to fit the ibiza, or was it for the golf bora etc... like the link in the first post?
Thanks.
I can't answer as a matter of fact, becasue I never saw the auction he purchased it from, but I would say there's a 99% chance it didn't, as most of these are made in the States, and they don't have Ibiza's there.
But as he says, the Golf, Bora, A3 etc have the same fitting - even 5 and 6 speed share the same kit so it will definately work.
Deleted member 12147
any links?
I posted a link in the first post.
Thanks.
When i bought mine the ibiza was listed in the auction, so was the mk4 golf, Bora and beetle. The guy who i bought it from doesn't sell them anymore, but the one in the link in my first post is definately the same.
Nov 2, 2004
9,335
South Wales
I got one. :D One of the boys bought one a while ago and never fitted it, so 20 quid later its mine.
Should be interesting to see what its like with the TT shifter as well. :D
20 valve ted
boorrrrm ttsssshhhh
Jul 22, 2007
187
huddersfield
ive just fitted my ebay copy without lifting the car! it was a bit tricky but im sure a lot easier than taking exhaust off. just used long nose pliers to remove the retaining washer thing that holds the selecter rod. i know ive got all the names of bits wrong but it only took me an hour to fit just need gear nob to finish now
djkobra
has any one tried using a short shifter like this (or a B&M)with a neuspeed short shifter the one that fit's on top of the gear box!!
20 valve ted
boorrrrm ttsssshhhh
Jul 22, 2007
187
huddersfield
sorry didnt take any pics but i took the gaiter off by lifting the black plastic centre console its attached to and there are 4 plastic pins holding the gaiter on. then to take the knob off theres a clip that needs takin off then it all slides off
20 valve ted
boorrrrm ttsssshhhh
Jul 22, 2007
187
huddersfield
even with the centre console off completly it is quite fiddly!
to get the centre off i undid the 2 screws under a cap behind the handbrake then there are 2 plastic 10mm nuts near the gear stick once undone the whole console should come out in 2 parts the one that goes up to the dash will come out but is a bit tight.
