Am I seeing right--it looks like the yellow Cupra on the back page has somekind of 4 pots fitted at the front? Is it a clever camera angle or is it an option I have missed?
. And if you really must have multi-pot brakes, there are far better alternatives to the Brembo's.
It doesn't need them. Having come from a Cupra R with Brembo's the Cupra's brakes are even better.
ok correct me if i am wrong but we are only talking around 10mm difference in diameter over the Cupra R's discs.
If the Cupra's brakes are the same as the S3's (and I'd be suprised if they are not), they are perfectly acceptable. Can't say they are any better or worse than the LCR's Brembo's. Seem to kick off similar amounts of brake dust. Pedal feel if far improved but the ABS does seem a little eager to kick in if you go over a small bump in the road when you're braking.
Exactly right. However, my origional point was that SEAT are advertising the new Cupra with 4 pots on yet they are not fitting them to the car?
Ah ok that could explain it--I am sure we will have reports back soon enough of how the new set up copes..I really do hope it is better as to completely get rid of the brembos fade whilst on the road would be great
