GGGGGRRRRRR EPC light
beattie17
1,353
Perth
Wen i put my key and turn it the epc and battery light come on and theyre only ones that stay on wen the car is started. Sometimes the engine light comes on over to the right. Any ideas? i dont have a clue
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
I had the epc light on mine at 1 point, the sensors that’s on the clutch peddle had come out causing that light to come on but not all the time.
Have a look under there is a white switch attached with a purple plug should go into the hole above the clutch peddle, when the clutch is realised the switch thing should be fully pressed in.
Hope this makes sense might not be this but just somet you can try :)
gavthelad
Bring on the Boooooost
Nov 19, 2005
1,394
Redditch (Midlands)
some people are buying them off ebay.......some seem to work and some dont, which ones do or dont is beyond me but id like to find out. Obviously the ross-tech one is going to be the best but will set you back about £100. I know some people have had problems with the usb type leads so the parrallel port one might be the best bet.
beattie17
1,353
Perth
will need to look into this. Disconnected battery and tried to reset ecu but nothing. Battery light is faintly on wen keys arent even in ignition(sp?)
And central locking comes and goes
