Transponder programming
Foxy
200bhp **** member no. 1
Oct 25, 2003
193
Daventry
www.pug306.net
As I knackered my transponder in my spare key, if I get another key from ebay and remove the transponder can it be programmed to my car via vagcom? Or is it a dealer only jobby
Theresias
Depends very much in your your and immobilizer generation. For example IMMO-3 transponders are being locked once they were matched to a car, after that you can re-learn them to this car as often as you want but there is no way you will ever match them to a different car.
Mind giving us some more details like the mode and model year (7th, 8th and 10th digit of your car's VIN)?
Foxy
Oct 25, 2003
193
Daventry
www.pug306.net
7th, 8th and 10th digit of your car's VIN =
1 M 1
If I can reprogram a new transponder that would be spotty dog! Im not 100% sure the transponder I have is new although the key is uncut its from ebay so may well have had another life, does this matter
Theresias
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
From my experience, the transponders don't tend to be re-programable, so if they have been previously coded to a different car, they will not work.
This is what happend to me, as of the two flip keys I bought of ebay, neither of them would program to my car.
You can check to make sure a key has the correct electronics in it so that it can be matched to the Immobilizer by:
[Select]
[17 - Instruments]
[Meas. Blocks - 08]
Group 022
[Go!]
The value in field 3 must be 1. If value is not 1, the key is not capable of being adapted to Immobilizer.
You can check each key in this manner.
I bought new transponders, cheap enough, from..
http://www.hickleyvaltone.com/diagno...ge=transponder
Mine were the Cypto 48 type..
