My new Brembo brakes...
Yumann
1,638
Glasgow
yea sods law, tho i was only warned by bill after i had purchased these! (not that bill needs to warn me! lol ;))
i must admit i had heard that drilled discs can crack, but i prefer the looks of drilled discs to groved ones (good excuse lol), but it was such a good price for the discs AND PADS that i thought it was worth the risk (and still do!)
also in the back of my mind i cannot help but think well if drilled discs are THAT bad then manufactures would not use them as OEM equipment...
anyways i dont want to dwell on this as i dont have any choice but to make sure i bed them in 110% and see what happens! (if anything does happen il be contacting the seller!)
anyway like i said i dont want to dwell ppl, so lets see what happens, fingers crossed! :)
The do look so much better than groved. I bought them cause of that too :lol: and also i couldn't get hold of 2 peicers in time for my mot.
Edited: Do you have different p/n for left and right discs? Cause i only got on p/n therefore the holes are in the oposite direction on either side.
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i only looked at one disc part no! :redface:
as for the holes... the patterns on both sides (driver/passenger) match!...
passenger side...
drivers side...
Yumann
1,638
Glasgow
Hmmmm thats strange cause according to brembo's catalogue there is only one p/n for both side.
Are your drilled holes counter sunk?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
just went and had a look (with the use of the trusty camera thank god!)... both discs do have the same part number, but they are not counter sunk! :blink:
Yumann
1,638
Glasgow
There are two different disc for the groved gt setup
Groved: 19.8403.30/40
However for the drilled setup there is only one disc kind
Drilled: 19.8403.20
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i guess that is because you can fit drilled discs either way, where as with grooved discs it is better that the groves go one way so to speak!
Yumann
1,638
Glasgow
Thats very weird indeed.
Cause it caught my eye that your discs arn't gold zinc plate there more like oe discs with grey primer.
I also noticed in the pic they are not counter sunk drilled holes.
:confused:
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
i guess therefore they are drilled OEM discs then?! :shrug:
anyways lol... no dwelling! ;)
and fingers crossed! :)
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
i had some of those "rotordiscs" a while back on my old mondeo. they looked the badgers nadgers but cracked in about three months and that was only using soft EBC greenstuff pads . it failed the MOT because of it and i got a full refund from blueflame for the discs and the pads! it is scary how bad the cracks get.
