More vibration after tyre fitting
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
I have a really strong feeling that after getting a new rear drivers side tyre, by a mobile fittier, there is a lot more vibration feeling through the steering wheel and seat on all speeds and surfaces.
Anything could of gone wrong?
DanGB
Feb 12, 2006
3,772
London
Wheels bolts are fine, ive since removed the wheel etc.
He put new weights on it, is that balancing? Didnt touch the car apart from putting it on again.
TimBarratt
435
Blandford
Its not been balanced properly. He may have put new weights on but it still maynot be balanced. The same thing happened to me. I took my car back and got the wheels balanced again and everything was fine.
TimBarratt
435
Blandford
All new tyres need to be balanced when they are put on a wheel, even a mobile fitter would have to do this. If they can't balance it, get them to pay for somewhere that can.
DanGB
Feb 12, 2006
3,772
London
Looking on the etyres website, it says they use a sophisticated balancing machine on each van.
What does balancing actually do and why would there be vibration?
Shall I ring up and complain?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Proper balancing involves spinning the wheel and tyre on a machine. The machine tells the fitter what weights need applying and where.
TimBarratt
435
Blandford
Yes definatly ring and complain, they shouldn't be vibrating.
DanGB
Feb 12, 2006
3,772
London
rung up and they said thy'll ring me back to arrange it to be sorted out. Nice and easy :)
AndyHazza
Ex-Awesome GTi Staff
Mar 30, 2005
1,455
Bolton
www.awesome-gti.co.uk
If you have weights on there then it should have been balanced. I'd give them a call and see if they can at least give them a check for you. A weight could have fallen off, if the wheel was wet when the weights were fitted then it could possibly have come loose.
Nov 2, 2006
1,241
Annaghmore
bebo.com
had this on a car, all 4 tyres slashed while in uni, mobile unit came out, shaked like mad after, eased off a bit and i never got it seen to for long time, ended up having gearbox, drive, bearing and brake troubles!! could/most likely contributed to it all.
