Anyone got a HAMMER??
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Maybe its something to do with your car wheel spinning in 3rd and 4th gear. Maybe that's the secret. Your reverse lights used to power up your ECU and do some magic to give it some extra ooommph.hahahahaha
On a more serious note, what a MYSTERY. Is the bulb holder giving out the right voltage?? Was gona say if the polarities haven't been switched, but think bulbs are bi-polar.
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
I had thought about negative polarity, due to fooling about with a Mk2 XR2 bodykit on to a Mk1 Fiesta years ago and having to seriously re-jig the rear wiring (due to the lights being in the clusters on the mk2 and being neg polar..) but im getting good voltage every time and none when i drop out of reverse.. as said, I even tried ANOTHER part in there (complete bulb holder section) and STILL THE SAME!!
its TRUE!! the car just DONT LIKE ME!!
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
This is sooooooo confusing,lol. Have you tried to run two wires from the reverse light wiring (just hook them up to the blue clips), and just attach those to the bulb?? Another possibility is that the voltage is there, but the current is really low. In fact so low that it wont light up the bulb.
p.s. you must be doing a lot of running around constantly putting the car into reverse, running to the back of the car to check. ALSO, maybe you have already managed to fix the problem at some point, but you didn't realise because you forgot to switch on the ignition.
Mig
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Well I'm off to the pub now, so I'm pretty sure I'll think of the solution to this mystery while drinking my favourite pint of wife beater :drunk: . And IF even that doesn't help, then it can only mean one thing.........your car is possessed.......by Pedro's ghost :scary:
Mig
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
well im goona behead a bottle of Jack Daniels tonight, so betwixt Myself and Jack , we may come up with an idea, even if it IS a 'Heath - Robinson' type one ;)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
not really as such, (too little time with far too many other commitments at moment) but speaking to an 'Auto -electrician' was told it sounds like a poor earth?? wil investingate as soon as , (think the MOT is due end feb, so need to ,really ;) )
