Combine Big Turbo conversion with LPG?
revo
GAME OVER
Aug 13, 2006
162
Belgium
revo.forumpro.fr
As the title said it, is it possible to combine a big turbo conversion with a lpg system? If it is, is it better to install the lpg system before the big turbo or is it better to install the big turbo first. Or perhaps is it the same?
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
Do you want LPG for economy? Your not talking propane injection etc?
As a point of fact most BT cars run with better economy than std cars, they are 'off turbo' till higher in the rev range hence people can sit at 85mph on the motorway with it barely spooling. This means you have economy of a 1.8 NA engine at motorway cruising speeds.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
prolly a question for a gas conversion company.. whether they would have noizzles/injectors of suitable size for a 4 banger running BT power (and conventional gasoline thirst)
eg... mine needs 900cc injectors for 98/99UL fuel, what can an LPG converter provide?
{extreme example I know}
mike_s14
105
staffs
I run lpg on my 350bhp nissan with success, am planning to go direct injection and run 450bhp with a 2ltr 4 pot [B)]
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
who did the conversion. std ecu, any tweeks?
i have heard from peeps who do these conversions that some suffer valve related issues (burnt) on LPG, which puts me off a bit.
considering LPG for my audi.
mike_s14
105
staffs
A local guy did mine 6 years ago to the car in standard trim, since then it has evolved with 3071 turbo, 740cc nismo injectors, poncams, apexi pfc, 1.8 mhg
ripping the emmigas system out soon and replacing with a direct injection system that I can hopefully run on the apexi ecu
getting a cast inlet manifold that I will be modifying and rebuilding a engine with forged bits to run around 500bhp [B)]
Niall
880
www.testrake.com
Jeroen Dik of JD Engineering in the netherlands has tuned several 1.8T engines that run on LPG, clue is that the temperature becomes higher when running LPG so that peak power has to come in at lower revs than standard to stop overheating of the cilinder head.
Conclusion you can do it but it needs custom mapping, but it does give slightly higher power due to the higher octane that LPG has.
