k04 ibiza
Nov 2, 2004
9,335
South Wales
I think mork was on about sticking it in stock mode via sps to calm the settings down until you sort out the fuelling problems.
If it was me i would use matched MAF/injectors. If your running a 3" MAF then your injectors need to match the fuelling to give more.
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
im not driving it tho so theres not much point of putting it in stock!?
PhilW, do you hace a pic of the s3 washer bottle your using? ive got one for mine but i doesnt look right!!
HoocH
Nov 2, 2004
9,335
South Wales
Mine has the cover on it, never really fitted right, the bottom front has no location and it pretty much floating in the air.
It took me ages to get it to sit right.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Someone gets me!
Fuelling is the kind of thing you wouldn't want to guess (and get wrong)
revo stage2 on OE injectors & OE maf will provide the code with the information it 'needs'
mess with either & you are in the unknown area that is either rich/lean/ perfect
rich does long term damage, lean will do too - especially if it melts a valve.
Scotty_b
Leon Cupra 300R
Jun 3, 2004
6,026
66
Hertfordshire
Does this mean you need a LCR lambda probe? (wide band) If so i have one spare and one on the car (rear ones switched off) if you need one to get you going? Or have i got the wrong probe?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I think you still need your rear one scott - it's not "off" just ignores the cat - I think it's still required for warm up
Plus it's the front one he needs (slightly different)
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
feel...just read my posts on page 1 and i do say its custom!? dont ask my why because like you said its a bam manifold!
HoocH
:yes:
its a proper k04 not a 001 one
not as easy as just changing it for the 023 mani! had to have a custom one made!
Latest news!
just got back from taking it for a spin and it is deadly, no traction in 1st, 2nd, and abit of 3rd but once your going its mad
will get pics up once i get a min!
HoocH
:confused:
Anyway, like you say (now) it's not custom. Did the Ibiza charge pipe line up okay with the K04 outlet? There's quite a few people who've thought about fitting K04-23 to K03 cars, but the intercooler piping has put them off - that might be the answer - Ibiza charge pipe to single pass FMIC to Golf/Cupra Inlet manifold :think:
h17och
Sep 1, 2005
3,504
Dunstabubble
i had to modify the support braket and get a 45 elbow for the turbo to charge pipe! its only temp tho! gonna run it round the side of the engine, like the bam lump
HoocH
h17och
Sep 1, 2005
3,504
Dunstabubble
h17och
Sep 1, 2005
3,504
Dunstabubble
its plugged in...checked that! but it seems to run well! whats that about? thought it would run crap if n75 wasnt wrkin?
HoocH
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
getting 19psi
eh?
somethings not plumbed right.
N75 electrically off is actuator pressure only... which if std spring/actuator is not supposed to be 19psi.
check the pipeing to actuator/N75 if I were you.
that does'nt sound right :confused:
