I'm always curious when remapped LCR's pull over 200g/s. I always seem to be putting out the same power levels on R/R's as other people with same mods and software but the max i've seen is 197g/sec. 225 is impressive.
Your torque at 300ft/lbs doesn't indicate extreme boost levels so if you are outputing high bhp levels (incomparison to others which the recent RR indicates) it must be from advanced timing etc. More indepth logs would be interesting.
Just be being a bit blond but are your recent R/R figs ATW or at the flywheel.
What settings do you use your stage 2 at.
