headunit
rogers
rogers
Jan 8, 2006
999
bridgend, south wales
right i need to know, how people get around the problem of the headunit, i know this as been posted befroe but would like to see pictures and peoples comments on how they have got around the problems, this is because i can have a in dash dvd for dirt cheap so would like to knw asap, thanks
davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
could build you a fibreglass pod for the center console if you pick up a spare one or anything else you suggest really!
scottys
131
easy peasy lol . all ya got to do is take the front of the head unit , then find some cat 6 data cable , and get from alpine the two parts that join the head unit to the face , then sit with a solder iron and magnifiying glass and solder the connections and match them both sides . with out makin the solder touch between the tracks , takes a good hour to solder , but the joys of workin in a stereo shop , so did it in me lunch break , and then re trimed the head lining , in black alcantara
beezaturbo
341
Staffordshire
my mate did his the same but fitted the fascia in the sun visor, looks very trick. i'm curently in the same boat i've got diamond sub rainbow components also amps and wiring just need a headunit then the job of fitting it to make it look oe
scottys
131
i got all that already in the car , had a fiber glass install in the boot and on the doors, wont post pics as most of ya already seen it lol
