Wheel alignment specifications and performance
geom
Hi all,
i am a new Leon Stylance 1.6 owner and today i went to the dealer for the first service around 1500km.
I had a feeling that something was not going fine and i asked them to check the wheel alignment....and i was right. The toe was out of range -0,2 (Left) +0,2 (Right) which is obviously wrong and they fixed it. They said me that the correct number is something about +/- 10 but i think it's something about +/-1.0 because with 10 degrees you cannot roll.
Then i wondered if someone know the official wheel alignment specifications.
I searched but i didnt find anything on the net...
And one more question for current owners, does the car accelerates better after some kilometers because i feel that above 4200 rpm it seems to hang a little.
geom
Ok, the correct settings for the front wheels are 0.5 degrees negative toe for each wheel and 0.2 - 0.7 negative camber.
For the rear wheels, if i saw clearly, it was about 0.05 degrees negative toe
Before the wheel alignment process i had noticed a little instability in high speeds but perfect cornering and i think this was the effect of the little positive toe setting. Now after the process and at 150km/h the steering wheel is more stable and has a safe feeling.
