Intermittent power loss during steady driving
Snarks
202
Lancashire
Visit site
I've been searching through this forum trying to find someone with a similar problem to mine.
Basically, during steady driving, i.e. constant speed not flooring the throttle, the power seems to cut out for a fraction of a second and then come back to normal again which produces a jolting sensation especially at lower speeds in first or second gear. It does it a few times a week and has been doing so for several months.
I waited until the service was due but the engine did not report any faults when connected to the computer.
I also notice that when starting from cold, the engine can sometimes "shake" for a second or two but then the revs go back to normal. I don't mean a rattling noise but from the driver's seat, it feels like the engine is trying to break free from its mountings.
Anyone any ideas?
D3DNA
391
Cov
No to sure but sounds like the dv valve. if the problem is more persistant around 2 to 3k rpms then its very likely.
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
im having this exact same issue at the mo, and yes big lad between 2 and 3k
no solutions as yet, but im on the case
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Hi think the problem could be similer to my mates golf. the problem he used to have when he is driving normal, the car jus dies out and the revs dies as well for 3seconds. Then all sudden a quick boost of power.
The problem was with oil pump, that its keep playing up. later as it got worser and the oil can symbol starts flashing but when check oil level every thing is fine.
the problem was the oil pump, get yours checked.
check for oil loss,
when was it last serviced as blocked can some times build up causing pressure in the pump
Regards
Big_daddy
Oct 20, 2006
3,930
Brummy
MAF should not cut jerk the car, like this did.
when my mates golf when in for a diagnostic, all the sensor where fine and nothing was coming up on fault screen.
Big_daddy
Oct 20, 2006
3,930
Brummy
there possible chance but we had the whole fuel tank treated and a new fuel filter put in. still the same.
Once on the motorway, the car started dieing again, then the oil symbol started beeping/flashing. Thats how i figured it. had AA on the side in the case of the worst
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
Recently ive been having the same sensation, ill not call it a problem as such.
I noticed today that my dv was a bit gunged up even though it was serviced a few k ago, luckily ive still got the old piston as it was replaced early anyway so im going to grease it up tonight and fit it, Im not convinced that this is whats causing it though as its not happening on boost (ie above 0 on the boost gauge) or if it does its not as noticeable. I suspect its the n75 or n249 fooking around, if i can get a lend of a spare n75 to test it out im going to try that then get rid of the n249.
Big_daddy
Oct 20, 2006
3,930
Brummy
i have the same forge dump vale - the one with logo printed on the side and vacum nozzle that spins around.
do these require servicing? i also got some additional spring included when i bought it
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
yup they do need servicing, you can do a pen test first or just remove it, clean it and re grease it and refit, ive been doing mine every 8-10k.
Snarks
202
Lancashire
Visit site
Thanks for the replies.
There's a company called Frank Massey Automotive Diagnostic Solutions in Preston. They seem to be recommended by some on these forums. I'll get in touch and see if they can diagnose any problems.
davebnly
I LOVE BOOST!
Aug 27, 2006
111
Lancashire
I have this exact same problem between 2-3K RPM, always have done since fitting the Forge DV from brand new, so i doubt its an issue of the DV needing service. Mine also has a remap though and it seems to make the juddering slightly more severe than one without.
Since it started happening i always assumed there will be no cure as its only happening under slow speed equaling vacuum in the manifold to open the DV slightly (as it is supposed to under vacuum).
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
I managed to fix mine temporarily with an ecu reset (battery disc for 5 mins) but it seems to come and go again after a load of miles, its not a problem as i mentioned before just a minor oddity, maybe the 249 removal might fix it.
