Power Loss
Edward McFadyen
Sometimes when driving my LCR, I go to floor it and I only get half the normal power. I stop and turn the car off then back on again and it's fine. This is an intermittent problem and only happens a few times a month but it well annoying.
The car is still in warranty so I want to get my local dealer to fix it but since it rarely happens, they would have to keep it in for awhile and do a lot of testing.
Can anyone help?
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
im new to all this aswell only had my car 2 months loving her 2 much and carnt get enuff.i think i hav either the same problem or similar with power loss,when im driving and it doesnt matter what speed im doin or gear im in,put my foot down and no power there it like its holding back let off for a few seconds and try again and its find any ideas? been told it could be N75 valve?? cheers 4 the help
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
I've had the same problem since buying my LCR, and after lots of research and reading it seems it could be any number of possible causes.
Dump Valve
N75
Wastegate problems
Leaking Pipe / Loose connection
ECU problem
MAF sensor... the list goes on, but those are the common problems.
So far I've changed my DV to a Forge 007P and while the car feels better when it's on song, it still loses power occasionally. Will try the N75 next I think.
CupraMVR
Oct 19, 2006
1,371
Crewe Cheshire
ive had it happen a few times now but it isnt all the time can go weeks before it happens again.car is 04 plate and still under warrenty,i hav forge 007P DV on it at the moment.
col1981
i have the same problem in my 270 lcr. I put it down to the traction control as it only does it in low gears when i try to put the power down quickly
bentaw
Revo'd LCR
Oct 1, 2004
1,067
Hampshire
its found at the back of your TIP(turo intake pipe) i believe it is a boost regualtor valve correct me if i am wrong guys, do a search and you will find pics of one
