MK3 Cupra Part Numbers
Oct 2, 2006
484
help
I have already found this thread very useful for a few parts, so many thanks, could anybody give me the part numbers for the l/h and r/h black pieces of plastic that fit above the interior door handles, that fit around the inside car door opening chrome lever hope this makes sense? iv just been fitting brand new interior door handles and broke one of the above doh!, so i thought id get a pair to match the new handles, cheers!;)
basstard
Dropping Cogs is Useless
Aug 24, 2002
2,746
Roma, Italia
Visit site
Cupra sideskirts [primed and ready for painting]:
left: 6k0 853 853 A GRU
right: 6k0 853 854 A GRU
Sideskirt jackpoint caps [primed]:
front left: 6k0 853 455 B GRU
front rite: 6k0 853 456 B GRU
rear left: 6k0 853 455 C GRU
rear rite: 6k0 853 456 C GRU
sideskirt back cover left: 6k0 853 657 GRU
sideskirt back cover rite: 6k0 853 658 GRU
centre front honeycomb grille with 'S' logo: 6k0 853 651 AA
centre front honeycomb lower grille: 6k0 853 677 C
left foglight housing for cupra bumper: 6k0 807 929 A
rite foglight housing for cupra bumper: 6k0 807 930 A
cupra left front foglight: 6k0 941 703 A
cupra rite front foglight: 6k0 941 704 A
basstard
Aug 24, 2002
2,746
Roma, Italia
Visit site
Been to the bodyshop and gave them the part #s for the black bump strips. when they were delivered we found out that the front: 6K0 807 225 D B41 has a square hole like the space for a headlight spray or something [the same hole is in the bumper but gets covered by the normal bumpstrip].
The rear: 6K0 807 425 F B41 hasn't the space for the regplate. This is very wierd cos I thought all rear bumpers were the same [except for the exhaust hole for diesels].
I think it's better to correct.
ganda_cupra
VW Commercial Technician
Sep 4, 2006
286
Near Sheffield
Cupra 1.8t
(all VW part numbers + retail prices, as work in a VW dealership, part numbers for belt, tensioner + water pump are same as SEAT as checked before fitting mine)
Cambelt kit (cambelt, tensioner and idler roller) 06A 198 119B @ £75.00 Exc vat
Water Pump metal blades (exchange) 06A 121 012X @ £25.80 Exc vat
Hope this helps people
Nov 2, 2004
9,335
South Wales
Suspension Mounts and Bearings
Front
6N0412331E
(6N0412331D)
Rear
191 512 333 (Lower)
191 512 335 (Upper)
Top mount bearings... (taken from the box)
6N0 412 249 C
Nov 2, 2004
9,335
South Wales
The top plastic part is...
1J0 937 555 cover for fuse holder
for models with battery: 44AH
adapt with workshop equipment
1J0 937 555 A cover for fuse holder
for models with battery: 60/70AH
1J0 937 555 B cover for fuse holder
for models with battery: 72AH
ChrisCurzon
4WD FTW
Apr 9, 2006
1,821
Bolton
I have the part number for the actual fuse box at home will add later just to be warned i tried to get it, they sell each bit separate i.e the cover and the bit that fuses go in, cost me 40.30 for the fuse box and an extra 5.70 for the fuse cover and you needs to use the old metal fuses out the old box unless you get new ones
blackie
I'm Tyrannosaurus Alan!!!
Im after this tooo....... :cry:
TingTongTec
im now armed with ETOS at home so if anyone needs anything or you can think of anything useful lemme know and ill slap the P/N's up
does anyone know the part number (or give me a chassis number for a LHD) as im after the LHD driver handles (without the keyhole)
TingTongTec
im after the Part number for a LHD passenger side exterior handle
cheers fella
