i'm running with revo stage3 on my lcr
but from what i understand the eliminators don't fit on lhd ?
I am surprised if thats true.. Is a US product who have LHD cars
Saying that though, it's been sorted at least once so it still seems like a good option, compared to what else is out there. Perhaps a discussion for a different thread.
Sorry by that i menat the way its controlled, i know the workinsg are far more complex but in operation i was suggesting. In other words its allot simpler to tweak the boost uning that if your driving than having to go into sub menues etc with an electronic version
Bill if i were to try CC rather than another jabbasport remap, what would happen with the CC mapping if i tried to use jabbas B.C?
It would still control the wastegate actuator would it not, allowing me to set boost from turbo?
Would it throw a wobbly though with fuelling/timing paramaters?
Ashame really as CC do not offer switchable on the move maps
Doesn't the Jabba boost controller "just" use the N75 valve? i.e., they don't use any additional hardware/plumbing? I can't see how that would help (although I'm not expert).
Don't you need some additional boost control to reduce the boost onset/boost taper, which is usually some other hardware/plumbing that bypasses or works in parallel with the standard N75?
AVC R sounds good. Don't Greddy do something? Something like the Turbo XS or a the two stage Dawes Device (used a lot on the Vortex IIRC).
Did jabba sport get back to you?
Vag Tech gave a rough idea of 5 hours work, so £250 plus vat
