VERY squeeky brembo's
jayblue
My LCR's brembo's squeek (as i think all of them do) when i'm coming to a stop gently, quite loudly. This doesn't bother me much. But they also squeek whenever i'm NOT breaking, upto a speed of about 50mph where the noise disappears. Does anyone else find this? The noise is so bad i can't drive the car with the window down it is so irritating!
jayblue
Just changed the front tyre's and a good look at disc's and pads. Disc's have got a lip coming on them, so i'm guessing thats why. Thanks for your replies. So new discs and pads just round the corner too by the look of things...
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Often do have a lip - the maximum wear on them is one millimeter per side (total of 2mm per disc).
So if you can lose a 1p coin against the lip...
km
Whats the mod for the rear? Mine make a hell of a racket. The fronts do too but its intemittant ... almost sounds like a wheel bearing is gone at times ..
km
Thought about it but cars 9mths old & done 8.5k so due service soon, was planning to get seat to look at it while it was in. the "fix" for the rear brakes interested me though ...
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
If you are a heavy braker the front pads can go in 8.5k miles or less, maybe the squeaking is worn pads......the sensor has been known not to come on even with pads down to the metal
tj_lcr04
mine squeak a bit going round the tight left hand bend into my work sumtimes :confused:
tj_lcr04
nah not braking round the bend, usually going fairly quick, but it aint tyres squealing and it sounds like just from one side and not everytime
km
I had a 200sx which had a similar problem...turned out one of the pistons was not releasing properly in the caliper. Does the noise go away when you press the brake pedal lightly with your left foot while driving round the corner?
Thanks Rudd... Front pads are ok still got some meat on them same with back ones which are squealing like hell every time I get to about 5 mph when stopping.... I don't expect them to be silent but the occasional droning from the front and squealing from the rear is a pain in the backside.
What is the "fix" for the rear brakes?
