I just need something to measure mine with... What milage are you at with that thickness?
You will need a micrometer to reach over the outer lip on the disc.
Milage is at 36K. No idea if these are the first or second set on as I have only had the car for 2K. 2nd set would be my guess.
My first set of discs lasted over 35k miles and that was using harder carbon metallic pads for half that time
I have just had my front discs and pads done at 41000 and that included 2 track days worth of wear....
It also only cost me £350 sourcing my own parts and getting JBS to fit.... Sounds like your steeler took you to the cleaners!
You should have fitted them yourself and saved even more money
If I had fitted them myself I would be paying for front end damage as well as getting them fitted properly afterwards!
Don't like doing things like that myself.... could probably do it but don't trust myself, plus could afford it this time...
I thought that but as long as you have a good guide / things planned out in your head, the right tools and take your time there's very little to go wrong with most things.
May be next time then...
They must have thought the min thickness was 27mm (yeah right). Its 26 (1mm per side) so your discs were only 45% worn.
What I meant was THEY hadn't bothered to measure it, I had to do it myself!
I've never had a dealer service my cars before but then I've never had one in warranty before. I need to find a good local specialist!
I was told by the dealer that my pads were 90% worn, which was true. But they also said my discs were corroded and worn and needed replacing. I found that the only corrosion was a slight lip around the outer edge of the disc.
I asked what the thickness was and they hadnt measured... I found it to be 27.1mm, and not ridged or grooved at all!
Also when I questioned why i was being charged for one unit of screenwash (about £1.50 I think), even though the bottle was full! the dealer said its because they drain all the washer fluid out and to stop it going stale and smelling!!! what a load of bull!!
I've bought my own pads from badger5 and will do it my self next time i'm home!
Won't be going back to Listers in Cov thats for sure!
