had nothing done with the screen, but last week, i took it to have air-con re-gassed and a new pollen/cabin filter put in, if only it didnt rain
has anyone had any problems with water in the foot wells?
That will be it
they havent put it back properly, very easy to sort out, wipers off, lift scuttle pannel, and push the rubber seal back under the plastic, very self explanitory when you see it.. just make sure you test it with a bucket of water to make sure you have fixed it before you put the wipers back on
lots of info here:
http://www.seatcupra.net/forums/showthread.php?t=44216&highlight=leon+leak
A bit off topic, sorry, but did you get the damage sorted? Natinal windscreens replaced mine last week and damaged the side trims and left most of the side trim clips broken. They said they would replace it all in a day or two and I haven't heard any thing since!!!
cheers for all the help and info, joys of motoring eh?
Had this on my S3, so the Leon being VAG it will probably be the same, the drain hole by the pollen filter or on the other side of the engine bay, they get blocked with leaves and stuff and the water comes into the footwell.
See pic on the S3, yellow marks the drain holes that the waters goes through down into the wheel arches..
Sorry these are at the base of the windscreen under the trim.
