Koni suspension
danb
53
Cambs
Koni FSD's and Eibach springs (now with pics)
Hi,
I have done a search but couldn't find what I needed?
I want to uprate the suspension on my 52 plate LCR. The general concensus appears to be to do both shocks and springs. I am looking at the Koni Sports Adjustables on Awesome Gti's website but they all say "excluding LCR"
So is there a special code for LCR versions of this kit or am I out of luck? Awesome want £305 for the kits - is this reasonable?
thanks in advance.....
(new suspension now on - see bottom of page for pics)
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
i think its because the LCR is a mix kit in that it uses part of a TT kit and part of a golf 4 kit
what drop are you after?
koni fsd shocks may be the way to go with some eibach springs
drop awesome gti a line and also big boys toys (both in discount forum) and see what they recommend
WeeJase
pert
Jun 2, 2001
8,595
fsd's are great.even with standard springs.different car, but real world difference from stnd shockers
danb
53
Cambs
does this mean that I can't use the 'sport adjustables' then? The price quite appealed to me! The fsd shock people mention - is this just the shocks? I'm looking for a 30 - 35 drop, nothing too drastic and I want to improve the handling.
thanks again
Brucel
334
Sheffield
I am getting Koni FSD's with Eibach springs, approximately 20-25mm drop...
Give Sarah a shout at Awesome she might be able to get you the sports adjustables it just may not be listed.... If not I am sure she can help with other suggestions...
danb
53
Cambs
Just to conclude this thread....
Today I had my new suspension fitted. I went for Koni FSD's and Eibach prokit springs.
It looks great and more importantly handling is improved. I would actually say the ride is more comfortable than standard. It feels more attached than the standard set up.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
If you can afford it later a couple of larger antiroll bars really compliment the lowered suspension. I had Bilstein PSS coilovers (about 20mm lowered) then added a Neuspeed 28mm rear and 25mm thick front ARB and it transformed the car.
shelby.68
hi dan,just read your post on your eibach set up.cant see when you posted it and was wondering how long thay've been on and are you still happy wiyh yhem as like many a lcr owner Im just in the process of looking for any upgrade advice.cheers
Mitchy
TTRS
Oct 12, 2004
2,310
On an LCR?
What price did you pay for the kit if you dont mind me asking? How much labour/fitting charges as suspension is the next mod on my list.
Getting really fed up with the harsh ride of the LCR now:(
AwesomeSarah
Forum Sponsor
Mar 6, 2006
727
Hi
Yes we can do the kit for the LCR
We have done the kit for the vRS too
Great kit
Handling is really improved and works exceptionally well with the OEM springs or the Eibah Pro kit
If I can help you just give me a shout on here or call me on 0161 7760777 and press option 1
Thanks for the mentions , we do the kit at a reduced price on the retail
Hope that helps you
Sarah
Brucel
334
Sheffield
ARB's are worth it without suspension.... they made a massive difference and Awsome do a great job with the Neuspeed ones....
Made an amazing difference and on track it made an even bigger difference... Worth every penny. :)
danb
53
Cambs
On an LCR?
Just over £500 for all the kit, springs and FSD's. My local garage did the work for £70 including alignment.
danb
53
Cambs
Only had them on for a couple of days and just did a long journey today including a mix of b roads and motorway. I would say the ride is actually better than standard, it seems to be a lot less crashy over low speed bumps. However the setup really comes into it's own along high speed b-roads, it felt really confident and planted.
I used to own a DC2 Integra Type R so I know what a good handling car should feel like. I was extremely dissapointed with the LCR's standard setup and this combination seems to have restored my faith.
If anyones interested I can post pictures so you can check out the ride height - this was a concern of mine before purchasing.
danb
53
Cambs
Not great pics unfortunately.
From experience the springs will settle to be a little lower but I am very happy with the look as it is. I think it retains the standard look - sort of how it 'should' have looked from the factory?[B)]
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
That looks stunning, nice one :) Not tooo low, but enough to make it sit nicely on the wheels.
How's the drive? Have you had problems with speed bumps, car parks or anything else where the front splitter may catch? I've already caught mine in a multi story car park so I'm wary of lowering it too much.
danb
53
Cambs
I haven't had any problems with the ride height as yet, and I live in an area with fairly rough roads! This was a consideration for me and I decided coilovers would end up being set at this height anyway so i'm glad I opted for this setup.
The drive is much improved, at high speeds the car feels more stable - as standard I though it wandered a bit on the rear. Around town you wouldn't even know, it's very smooth.
I know anyone who gets new suspension really raves about it but I recommend the FSD's, they live up to my expectations.
jetsetjimbo
a.k.a James
Jun 12, 2005
630
J2 M5
Is the low speed ride less crashy than the standard setup? Did you go for the ARBs too and have you got a front strut brace?
I've been looking at the FSDs for a while...
danb
53
Cambs
I think it is firmer at low speeds but definately less crashy.... if that makes sense!! What I mean is you don't loose fillings when going over pot holes! I always found my self avoiding any rough low speed surfaces with the standard setup - the FSD's seem a big improvement. My car has only covered 25k, on a 52 plate so they weren't exactely worn.
I just went for the springs and shocks, I want to add bits gradually to see the effect. My next mod may well be a front brace.
