how do you rest the ECU? (yes iv searched!)
ok i know that you can do this by disconnecting the battery but it doesnt seam to work for me!
can you reset the ECU with vag com?!
bassically i am playing around with Custom Code software and i tried the speed limiter thingy, so when i take my car in for a service i can put a speed limiter on it so no one car rag it!
at first i tried the speed limiter at + 40kmH went for a drive and expected it to work and then realised that it should be minus!
so i set it to -128kmH (so if the car can do 150mph it should now be limited to about 90mph right?!)
thinking about it... do you think this didnt work as the LCR doesnt have a limiter as standard so thus u cannot adjust it?!
anyways the reason for this thread... after loading the new settings to the ECU it says... "the new ECU settings have been written correct. Please cycle ECU power for settings to take effect."
i have disconnected the battery for 20mins and that made no difference.
someone told me i need to pull the instrament pannel fuse out whilst using custom code and that didnt work either!
can anyone help? (how do i cycle ECU power?)
cheers!
cheers!
