Engine revving itself!
CushnerCupra
Need some help guys!
I own an ibiza cupra and recently on long journeys my car has started revving itself!
It only occurs when on a longish journey 30 - 40+ minutes less if you driving the car hard. If for example i accelerate upto 3k in second gear and then let off to change gear the car will rev itself upto 4.5k and then drop down. This happens in every gear and it revs higher if you accelerate to a higher rpm e.g if I acccelerate upto 5k it will rev itself right on to the limiter a 7k and then drop back down.
It also happens if I accelerate and then just let off the car will carry on accelerating which is worrying!!
I had vac-com plugged into to see if there were any faults occuring but there wasn't any.
The car is going back into the garage on wed where they are going to take the car out when it is doing it to do some logging but any help from you guys on what the problem is or how to fix it will be much appreciated!
Harry
p.s I have an a switchable APR re-map and the revving is worse when the remap is on!
Reactions: Sandman
Stevo1
577
St Ives, Cambs
Harry, the most probable cause is your clutch sensor. Have a look in the region right at the top of your clutch pedal, and you should see a white sensor clip (it is like a long thin white point plugged into a holder.........not the best design in the world). Check this is firmly plugged together. Mine was slightly loose and it made the car rev in between gear changes.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
Clutch Pedal shows a fault though (and a dashboard light)
Check for loose hoses (small ones) near the inlet manifold too
flashbsd
as above, but i didnt get a fault when sensor came loose, you will find that its stripped its thread and it needs pushing back in so that the pedal makes contact, else as m0rk say, its come unplugged and you have a fault light?
sloppycupra
Nath.....
Apr 16, 2006
81
is this sensor the one thats attached to the throttle pedal? but is positioned above the clutch pedal? as my car is doing the same!
mwarr777
11
Did you ever get this fixed? i have the exact same problem, and i have tried so many things... it is so frustrating, i need to sell the car and i cant if it revs between gear changes would really appreciate knowing how you fixed this(i know it was a long time ago)
mwarr777
11
Harry
