VT86, Seat Leon4 4wd k03 285hp => GT28R => GTX2867R Gen2 420hp
VT86
Leon 1.8 "CupraR" 4x4
Mar 22, 2012
325
68
Helsinki, Finland
Thanks, I like to try on do different things and learn on the way and as an engineer I can not pass opportunity like this even there obviously has some risks also.
Appreciate your feedback :) and yes that bus didn't even arrive
Reactions: Wyld Stallyn
MoToJoJo
787
600
Northants
Hadn't thought about cryo, and now I've gone down that rabbit hole 😅 Thinking of getting the gears coated as well because why not.
Just looked at the Epytec stuff, SOOOO much cheaper than the versions I've seen in the UK.
VT86
Mar 22, 2012
325
68
Helsinki, Finland
Finally putting gearbox back together, few holes drilled to case and some small work with angle grinder.
Cleaned and installed 4th gear support. Also added sealant to case strengthen kit bolts.
Case back and shifter tower installed, and found all 6 gears and reverse. Seems that managed to get everything back on their place. Case bolts need to double checked and then it's ready to go back to the car
