Seat Leon Cupra Widebody AWD Built Engine, Now Interior + Further tuning of engine !
mYGeL
Cupra Widebody
small updates :)
done little more with interior.
as i couldnt find any Sportster CS for reasonable price I decided to use the OEM ones and remodelled them.
here you can see some pics of the work we done so far. :)
This is my friend Micce that helps and teaches me how to sew and do interior :)
haha i can work also :p
thats all interior pics for now more later this week :)
Got all parts from INA And PAGParts and engine is built and ready to go in to the car :)
Its not completly dry yet thoughr at painter :p
now also engine room will be green. instead of black. here is before clearcoat
heres after about 6 layers of clearcoat will be even more :)
2 pics from the first package from Pagparts :)
PPT .72AR exhoust side, Ceramic coated for my GTX71 turbo :)
PPT SS Vband Cast manifold Ceramic coated
Finally i have only Vband so no blown gaskets no more..
First part of the PPT 3" Downpipe,
Also have got my Custom IC made by Pagparts based on Garett core and also hard pipes all way from turbo.
Also PPT intake etc
pics will come later. :)
one pic of my front brake calipers :)
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Awesome parts there mate, love the work going into this to push it into insane territory :D
Brakes look mega! IC hard piping, mmm :)
Good work!
Blair
Very very very... did I mention very, tidy indeed! Some top notch work!! Looks brilliant mate!
mYGeL
Cupra Widebody
This is for a little future Rear brake project..
Missing the Loggo on them here. But will come on soon enough :)
Got my new tyres from Pirelli today ! :D
www.pirelli.com
Pirelli P-Zero Trofeo R 235/35 -19
Some good to know info.. :)
Power Is Nothing Without Control !
And first tracktest will be in 3 weeks with these :D
Hope i have time to look over the mapping av Ecu first So it works with the lower CR and Ported head.
7 days left to get this togheter and be at Elmia Custom Motorshow, Swedens biggest Indoor Car show.. So we have little left to do..
Body is fully painted just the rest left now... :p
think i will need some luck to manage to get this done haha :whistle:
mYGeL
Cupra Widebody
The next 7 days are going to pass like 7 hours! Fantastic work as always :clap:
yep they flew away very fast. and sadly we had to cancel the plans in last minute. :(
now im home again from the show. and we will continue the work.
Stunning motor mate
Thanks mate :)
Do you need to trim the bumper for that FMIC?
no did not trim the bumper but it is very big and thick so you need to trim so it can be mowed backwards. but it is nearly to big but will fitt if you want it to :)
mYGeL
Cupra Widebody
:wtf:
last week was very unlucky with much things..
first on Monday i got hit in my Girlfriends car so bad it couldnt be driven away from the place..
it hurts in my neck and back. But instead of going to hospital i went to garage after i collected my saab in the other garage..
i drove with that one day then i thought it felt strange in the rear end. checked the tyres could see anything so continued to drive..
but it got worse so i put the car on the lift to check..
i didnt se anything when i checked first as it was Runflat tyres..
both rear tyres was like this on the inside. :p
Then the next day after i fixed that i drove to collect my rims.
first the engine totaled on the drive way to the tyre guy.. first i ran in and collected my rims.
Then try to get help to tow the car away.. then wait for a couple of hours so i could get a car to drive with and colect the other missing parts to get the car ready..
while i was waiting for a car i noticed they have damaged all my rims on the inside.. so now i will have to deal with them and that also..
Many valuable hours last week was just wasted away.. :(
then we tried to start the engine. and it did not start. The Engine builder came to assist and help us find out why. we tried some things as changing coilpack, sparkplugs, injectors, ecu, wiring harness checked timing etc.. all was good.
but no compression in engine cyl1 rest has compression but very low..
probably lifters that doesnt close, or in worst case the valve needs to be trimmed slightly shorter. but that also not a big problem just sad we didnt have time to fix it before show. if not the all other should have happened we would hav e tried to start engine eralier in week and then seen the problems and fixed it..
so i borrowed trailer so we could try to get it there.. worked for but was hard to drive as we couldnt get the car as long upfront as we wanted to.. so all over 40-50kmh was causing it to wobble.. then we also got a flat tyre.. when we came there we gave upp. left the car and drove without it to the show.. so was mixed feelings there this week and still is..
but heres some pics instead of text and wrong spellings :p
Time to work...
(yes it is a styled Bentley there :p and a Widebody Mini )
Engine is in now just the rest left to do.... :p
did not want to waste the space and have the S3 Ic there now when it would not be used no longer so we modified to just keep the ac cooler and the radioator..
test fitting and connecting the hardpipes..
testing placement of IC and Oil cooler.. both not on final places in this pic..
IC is fitted correct now. just some smal adjustments to get Oil cooler sligly higher.
in the middle of all this I got this Package :D
will be really interresting to see what the CATCAMS will do with the engine performance etc :) but firts i will do a Engine break in. Then Dyno With the S3 Cams and after that Dyno and tune with the CATCAMS :) and will post result with them both here :)
Had to go get 2 more 90 degre AN Fitting and 1 meter extra Hose to the oilcooler..
Also i hate looking after tools so i got a extra set of tools so we should save little time there.. Also a sandwich adaptor to my Metal oil filter as i converted to that instead now with the oil cooler kit..
Mocal Oil termostat to cooler..
Discrete AN couplings. :)
I dont like them Rainbow coloured AN couplings :p
1,8t Oil Pump and Balance shaft Delete :)
Heres some interior pics. it is more done than i will show here just beacause i havent uploaded all the pics yet to internet.. :p
The rear sides of the Front Seats..
here they are ready..
Heres the dash ready to be Glued togheter...
Here im gluing it togheter and tried so parts still fit :p
this pieces is the parts for the front seats.. Black leather, dark grey Alcantara and a small piece of green alcantara. togheter with green stictes.
here its not attached on the rear so not stretched out as it will be later just to see how it looks. :)
Like this I had to leave the car as there was no chance getting iut to show before to late :'( So close but still not.. But some forces did not want it to be there this year... :(
now i ran out of pictures for now. but i have much more pics on interior etc to upload later. Now im trying to plan this week and get it running correct this weekend. :)
Evalious
7
sooo do you mind if i copy your bodywork & colour ?? :p joking hehehe. everytime i see your car i get excited.( i know it sounds strange but its one heck of a leon ) and now taht you are back.. maybe you can check for me about the widebody kit, before i get mine into the spraying booth also.
the one i found from romania told me it costs about 1500 euros to buy , and also said that i had to do lots of fixing and cutting.
btw what do you think about O.Z. superforgiata matte balck on a grey leon with matte black bonnet,roof and spoiler ?
aherne746
this is one hell of an epic RR. absolutely loving the custom seats, and thew colour choice works really well. look forward to seeing what happens next.lol
Roganjosh
445
Epic build dunno how im only seeing this now! Love that spoiler! Mugen fn2 inspired by any chance???
