Seat Ibiza Washer problems
ChloLo
hi all,
Have tried searching the threads, but haven’t managed to find a clear answer. Following the recent rubbish weather I’ve had no ends of problems with my windscreen and rear window washers. First time the fuses blew, they have been changed and everything worked for a while. Now I have no fluid! As I can hear the motor its not that, I haven’t found/seen an obvious leak, the tank is still full to the top, so I assume it’s not leaking. I have also checked the nozzles aren’t blocked. What else can I check before I admit defeat and send it to a garage. Because they’ll take one look at me and try and tell me more needs fixing than actually does.
Also I’m no mechanic so detailed instructions please
cheshire cat
1,813
cheshire
sounds like an inlet filter blockage will need to pull the pump to check could try putting some compressed air (bike pump not garage line) down the common pipe to see if backflush will help if so its only temporary strip and clean
