Sim said:
The N249 valve is (should be) there for safety reasons i believe. It is there for one and only purpose: it gives the ECU control over on the DV at full throttle (when no vacuum is available). Just read my first post - it can also
help N75 to regulate boost, too. Also its name "Turbo Bypass Valve" tells it all. No tuning engine wants to bypass the turbo
Ok cool, thanks for that mate
but just another question i read from the Vortex forum, the main point of this is to allow the turbo to sustain higher amounts of boost higher up the rev range
for example with the N249 valve, some people are running 13PSI at 6000RPM with a chipped car
without the N249 valve, people are now running 17PSI at 6000RPM wth a chipped car
now that increase of 4PSI and 6000RPM , surely that is creating alot more strain on the turbo no? i just need to know if the K03S can really cope with that amount of battering, not that it already doesn't but you can see my point, the N249 valve being in place to perhaps prolong the turbo a bit more.......
maybe i am just being too cautious, but maybe something to bear in mind if i am half right?
what is the threshold for the K03s anyway? i know Jabba map it within its capabilities anyway so not to risk detonation of course, so i hope the N249 valve wont really cause much more strain on the turbo...........
cheers
Tony
