plaese help
CuPRaCaN
99
plaese help, oil pressure guage
couldnt find what i wanted with a search, please help. ive got a mechanical oil pressure gauge from nomad, i just want to know where i screw the bit into. its a copper brass coloured thing withv two different threads on it.
cheers rich
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
does it have an external thread one end and an internal one the other ??
better still gis a piccy if you can
if i remember right the oil pressure switch/sensor is in the cooler housing on the top of the oil filter
most mechanical gauges use an adaptor - you remove the sensor and fit the adaptor in enabling both the original sensor and a supply to the gauge to both be fitted in the same hole
wotever you do dont kink the pipe or let it get kinked - keep it as smooth a run as possible
show us a pic if you can
CuPRaCaN
99
both external threads, dont have picture im afraid, might be able to send you one off my phone. ill go and get it.
