Ibiza 6j with highline display (Maxidot cluster) mod in PROGRESS
explorer
100
27
Hi, I am working on retrofitting highline premium (Maxidot) cluster as in premium vw cars to Ibiza 6j. First step is finished and hw is working fine now, next step is reworking of the plastic cover for new cluster.
Video here:
Code:
https://youtube.com/watch?v=3bWZrH2m3Z4
explorer
100
27
So, I have finished cluster retrofit prototype.
With the cover there is the biggest problem separate pelxiglas (which is glued to abs plastic) without damage.
On the abs plastic is extended window for bigger lcd screen. I have printed outside plastic cover for bigger lcd.
3D printed outside cover inside abs plastic(without finishing & mounting):
Complete cluster:
explorer
100
27
It is possible to access to menu with maxidot cluster without multifunction steering wheel. In the menu there is possible to set some functions , language .... I will try to enable menu access and I will make video. If you interrested about maxidot cluster for Ibiza 6j you can write me PM.
explorer
100
27
Menu oil temp can be disabled in final version - it is possible via eeprom. Oil temp not be readed in test, but I must labor more with this cluster connected to car beacuse I make only one test and oil temp was --- with motor stopped. With started motor I doesnt check this value. I doesnt know If there is oil temp value send via can bus or not at the moment.
UPDATE:
Oil temp is sending from ECU only during car driving. I will test all functions at the weekend.
Sinan
Toronegra!
Dec 1, 2009
282
Turkey - Izmir
www.vagturk.net
UPDATE:
following, I don't know if possible but Polar FIS could be integrated also, any plans about it?
explorer
100
27
Yes with this cluster is possible to integrate Polar FIS. I am planning make my own module like Polar FIS soon. I had no time at the weekend to mount cluster but during this week I will make it.
explorer
100
27
So yesterday I was testing it. All functions are working, oil and coolant temp is reading fine. But I have one problem, when I check dtc there is only one problem but with abs module. Abs module throw error
Code:
Address 03: ABS Brakes       Labels: 6J0-907-37x-ESP.clb
Control Module Part Number: 6R0 907 379 AK    HW: 6R0 907 379 AF
  Component and/or Version: ESP8.2i front H05 0001
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
            004 - No Signal/Communication - Intermittent
So I will finding solution but I think that abs recoding is solution.
I will upload presentation video.
explorer
100
27
So I make wideo described all functions of the new cluster.
Code:
youtube.com/watch?v=QqAizAgoo70
explorer
100
27
I have good news. Project is finished. Highline cluster is installed into car, fully working without canbus errors. Abs module work fine with new cluster after cluster modification before there was problem with recognision of the new cluster by abs module. My solution is now plug and play. I need only immo data and I can make plug and play cluster without need abs recoding.
Final preview here:
Code:
youtube.com/watch?v=P_y7XMOVonw
Reactions: joe_ibiza_6j
explorer
100
27
I have tested new cluster in car for two weeks without problems. I am glad with this modification. All functions are working included backlight adjuster in night mode.
Amazing work, any guide?
This mod is hard to make - include sw changes, immobiliser pairing, cluster plastic case modification but I can make for sell complete cluster plug and play if I have old cluster or immo data from your cluster.
Andresv87
66
Bogotá, Colombia
What could be a cost for plug and play cluster?
Enviado desde mi Nexus 6 mediante Tapatalk
Feb 6, 2019
21
Can you PM price
vgf
UPDATE:
wow, great work and valuable info about oil temp reads. congrats.
MIH11MI6
20
Norwich/ Crewe
UPDATE:
Hi, I have completed this modification myself, including the immo transfer via EEPROM. what EEPROM change did you make to the cluster to remove the oil sensor light issue on ignition only?
