Faulty secondary water pump
Noam
182
All is good fuse wise but the original 9 year pump is cutting out and not always working.
How important is this pump during driving? . I know it's purpose after stalling the engine .
But my mechanic reckons it's important while driving too.
What to do?
Repair?
Replace?
Any truth in it's importance while driving?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Think mine may be on the way out aswell, started making a strange noise thats not the same as normal. Still works, but it makes a strange whining noise like a strangled cat or something!:confused:
Is it a big job to replace?
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Good good, thats another part to add to the list along with an ABS wheel sensor.
Will the turbo get damaged if the 2nd water pump is not working? Suppose, i do anyway though, drive off boost 5mins before the end of the journey to keep the turbo from getting too hot before i turn it off.
Noam
182
After replacing it my mechanic proved using a stethoscope that it works during driving too .
A common misconception disproved then :)
May 25, 2008
2,400
cambs
this is also controlled by the trouble some fuse ,the far right on top of the battery i found this out when i bypassed that fuse
flooky
Mine does this every now and then, while looking into it I found the noise goes away if you put pressure on the power connector! Almost has if it has a dodgey connection!
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
Did a quick search in the part numbers thread and i can't seem to find the part number for the secondary water pump. Does anyone have it at all?
