bonnet seal? power cable fitment?
alex 80
91
couple of questions for you knowledgeable lot
1. where do you get the bonnet seals that alot have you all fitted to the inside of your bonnet at the front?? how much?
2. where have you run your power cables through for your amps in the boot can't seem to see any gromets that mine might go through
oh if needed its an 05 fr
thanks for any advice
D.K
LCR 225
Oct 24, 2007
6,408
se london
1) The bonnet sea; is availble from Seat and cost about £7, TBH they dont do much, I'v removed mine.
2) In the hole where the pollen filter sits is a gromit that you can feed the cable through, you will need to remove the glove box though
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
Depending on how powerful your amplifiers are I'd take a fused feed off the bottom of the relay plate...
They are a direct feed from the battery so connecting them there will be fine.
http://www.icecavern.com/howtos/leonlowerdashtrim/main.php
