Alarm keeps going off - and Door Control Modiule Drivers side missing
unclebob
98
Hi all,
I have a 2005 Seat Altea, 2.0 tdi sport. Use to be driven daily up to this time last year, and then even less once uk lockdown hit... Mainly sits in the drive now so condensation / cold may be playing a factor...
Over the last day + night the alarm in the car randomly goes off, nothing untoward, just unlock and re lock and alarm stops for a while.
Its getting worse occurring more frequently.
I took the car for a drive earlier in the day and noticed that none of the functions of the driver door (ie the elec windows + enable/disable passenger windows) + the lock and unlock button in the central console worked or lit up... A little while later they worked again, then stopped...
three things:
1) is there a way to disable the alarm? From what I have found there is a yellow turn lock on the passengers door - I did that, but alarm still went off a little while later. I took the main battery off and the alarm sounded as well.
2) I did a scan using vcds. Logs attached:
Code:
(No subject)
Sunday,10,January,2021,19:17:36:38462
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x64
VCDS Version: 20.12.0.1 (x64)
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN:
Mileage: 237400km-147513mi   Repair Order:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: VSSZZZ5P   Mileage: 237400km-147513miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 HE    HW: 028 101 229 1
   Component: R4 2,0L EDC G000SG  7000
   Revision: 12345678    Serial number: SEZ7Z0E3077378
   Coding: 0050072
   Shop #: WSC 06402 785 00200
   VCID: 6DDACB067407C0ECD9-8038
1 Fault Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 840 /min
                    Torque: 48.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00101100
                    Temperature: 13.5°C
                    Bin. Bits: 10110000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0006898
   VCID: 408442B21315FD8442-8014
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 5P0 907 044 B
   Component: ClimatronicPQ35 006 0203
   Shop #: WSC 00000 000 00000
   VCID: 2F66110EBE8B72FCAB-807A
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003392571
   Coding: 81880F2700041000001E00000100000000007F0B5C
   VCID: 2B5E051E8A930EDC87-807E
   Subsystem 1 - Part No: 5P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer SE359  012  0402
   Coding: 00056272
   Shop #: WSC 06402
1 Fault Found:
01331 - Door Control Module; Driver Side (J386)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 17
                    Reset counter: 75
                    Mileage: 237404 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.25 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0002042
   VCID: 77F6E96E065B7A3C33-8022
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: E0221           004 0060
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001056308A85
   Coding: 3D3F0340078203
   VCID: 2A50001A856917D47C-807E
1 Fault Found:
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 10
                    Reset counter: 115
                    Mileage: 237404 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:47:00
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Part No: 5P0 920 923 A
   Component: IMMO            VO3 0616
   Shop #: WSC 01069 210 103434
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V2.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 336E1D7E52A3561CCF-8066
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 - -
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 19C000DC2D0005054C5F863000CC
   Shop #: WSC 01069 210 174572
   VCID: 79F2EF56304F6C4C45-802C
   Subsystem 5 - Part No: 5P0 951 171 C
   Component: Innenraumueberw.009 4865
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
1 Fault Found:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Component: Tuer-SG         024 2432
   Coding: 0000656
   VCID: 38742A524BC5B544FA-806C
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2426
   Coding: 0000144
   VCID: 3260187AADB95F14C4-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
End
The key error is the door control module no signal/communication...
I'm guessing these two are linked, and that either I have a wiring or control unit problem?
Is there a way from VCDS to get the part number or can I look it up else where to order a replacement? (I'd rather open the door card once and check wiring and replace unit at the same time then open the door card to check wiring and then close it backup to order a unit if possible?)
3) Anyone got a guide for replacing the unit? Its the drivers door...
unclebob
98
Hi all, Just to follow up,
1) I figured out from reading numerous threads that the process was to lock the car using the internal switch from the passengers side, then use the yellow manual lock to lock the passengers door - this worked fine but now the internal switch is no longer functioning - The car has sat for a number of weeks with a flat battery?
2) Any ideas where I can find the part number for the door control unit without taking the door card off?
unclebob
98
Hi AlteaXL thanks for the info - Since the battery went flat, i've lost use of all of the drivers door controls, AND the internal lock/unlock. Remote lock/unlock still works for the passenger doors! Now im not sure if its the drivers door control unit or something else! as the car seems to think that the drivers door is closed which means the alarm has stopped going off now! I'll take a look at the part number above!
unclebob
98
So I finally had the door card off and checked the part number - 1K0 959 793 H, so time to start shopping...
Meanwhile my battery keeps draining - to the extent where the windows wont go up as the motor is drawing more then the battery can supply!
I'm not sure if this is being caused by the drivers door constantly showing as open/closed etc and prepping engine to start and repeating, causing the battery to drain?
unclebob
98
Just as a follow up to anyone else who has a similar issue, I swapped out the control unit with a second hand one from a scrap yard (Note I kept my original window motor and just swapped out the control unit!), put everything back together and recoded the unit to match what I think I have and so far all is good. Battery isn't draining like it was before, and so far 5 days later the alarm has not gone off once. Locking is working again, as are mirrors etc.
Only issue I have is that the mirror control - where pushing the electric mirror adjustment forward tilted the mirror up, it now tilts right, back on the adjustment tilts left and so on... near side is working as it should, just the drivers side isnt!
