VCDS coding - faults found - help
balalaika
34
Slovenia
Hi,
i have Saet Leon mk2, year 2012 and today i played with: VAG COM HEX V2 USB Interface VagCom OBD2 Testers FOR VW AUDI Skoda Seat
All turn signals worked normally before playing. Now my left and right turn signals under the mirrors are not working. The other lights are on normally despite the error about the rear lights. When starting the vehicle, a warning light appears:
img-1069-jpg.260813
Can anyone help? What to do? I didn't autoscan before playing, but I did it now and that's why I'm sending the log.
Monday,09,October,2023,00:37:40:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0
Data version: 20230421 DS346.2
VIN: License Plate: 8888888888888
Mileage: 170630km-106024mi Repair Order:
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72
VIN: Mileage: 170630km-106024miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 5K0 937 087 R HW: 5K0 937 087 R
Component: BCM PQ35 H 021 0064
Revision: BE021001
Coding: 46180A3E80250CC042080080950009C442750008627D8D60008040000040
Shop #: WSC 04941 123 12345
VCID: 4487F917C79BD6B3AF-8010
Subsystem 1 - Part No: 1P0 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 13031 26 0611
Coding: 00DB90
4 Faults Found:
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 157
Mileage: 170639 km
Time Indication: 0
Date: 2018.03.01
Time: 19:50:12
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 157
Mileage: 170639 km
Time Indication: 0
Date: 2018.03.01
Time: 20:04:50
Freeze Frame:
Term 15 On
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
01179 - Incorrect Key Programming
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 156
Mileage: 170631 km
Time Indication: 0
Date: 2018.03.01
Time: 22:24:21
Freeze Frame:
Term 15 On
Voltage: 12.15 V
ON
ON
OFF
OFF
OFF
01520 - Rain and Light Recognition Sensor (G397)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 170357 km
Time Indication: 0
Date: 2018.03.01
Time: 18:10:09
Freeze Frame:
Term 15 On
Voltage: 12.10 V
ON
ON
OFF
OFF
OFF
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 142 3305
Revision: 00H22000
Shop #: WSC 06402 785 00200
VCID: 377D9EDB464D8D2B3A-8062
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 156
Mileage: 170631 km
Time Indication: 0
Date: 2018.03.01
Time: 22:57:39
Freeze Frame:
Voltage: 12.13 V
DD
Temperature: 26.0°C
RPM: 0 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
