mazzerati
Bags are for groceries!
Jun 27, 2008
1,980
Beverley, East Yorkshire
now then, when i go round a left hand corner, brake and acclerate hard i get a horrible knocking noise.
ive changed all the bushes like console ones, arb, droplinks.
i can sometimes feel it through the brake pedal
its happens quite alot but not everytime
the sound it makes is like a knocking
its starting to get worrying now so yer.
help me:cry:
about 8 months ago i think. one of the couplings had broken off that hold the pads back but i replaced that. maybe its pinged off again
Are you sure that you are not talking about rear brake shoes? (and not pads)
If you have rear drum brakes then its the actuating levers that seize up, but I'd doubt if that would make noises like you are describing at the unique times you are hearing them - mind you, you might be locking up a rear wheel on braking and after the pedal is initially released - if the shoes are seizing - jack it up and see it feels like before and after applying the brakes - or check if the rear wheels are hot or warm after a run.
ive only just changed the cv joints so i hope it isnt them again:confused: haha
ill do what you said with the rear brakes today see what happens.
cos its rather driving me nuts now! :)
