Yellow EML light on
Das Chin
214
12
Afternoon all and what a lovely day
was on the motorway earlier for about 50 miles. pulled off and up to lights
the yellow EML light came on - could it be CAT or O2 sensor more likely?
car is running fine. it's a 300 estate which has stage one chip plus the Racingline R600 air intake system with silicone hose.
i dud take the oil filler cap off to top off and wondering if some air has got in and triggered the air monitoring system?
same as this: https://progressiveparts.com/produc...take-system-for-2-0t-190ps-models-vwr12g7r602
thanks
Das Chin
214
12
plugged in the OBD II reader and its come up with Air Intake system leak
could that be the R intake pipe? or maybe a sensor?
Das Chin
214
12
which bits do you mean? the intake pipe from the air box and into the turbo? did check all around it and nothing feels loose
the only thing I have done different is top the car up with half a litre and then the problem came about 40 miles later.
wondering if maybe the dipstick needs to be replaced and oil cap maybe? car is 17 plate and 100k miles.
H Rafiq
1,172
492
I mean all the intake connections from the airbox up to the turbo elbow. Any oil in or on the turbo elbow, or intake hose? Any other error codes?
Das Chin
214
12
i switched the oil cap around and seems to be fine after a drive.
I noticed a bit of oil residue on the brake cylinder so maybe it was not on properly. will keep updated.
Reactions: H Rafiq
